Bad_Vision
Moderator
if you have the time and the determination to pull it you might as well.
if you pull it and the valves did just need adjustment at least then you'll have new head gaskets and you'll know for sure what the issue is.
i say do it! pull it and do a good inspection measuring tolerance on the parts put new valve seals in wile you are at it.
if it was just adjustment at least youll have the comfort of knowing that!
