help Electrical Drawings 5th
C'mon [MENTION=46138]chmura[/MENTION], he just wants a little help.
J/K
See here
http://www.toyota-4runner.org/5th-gen-t4rs/92594-modifications-write-ups-quick-links-faqs.html
^^Actually, the negative post is closer to the firewall, your drawing can be misleading :nono:
I should have clarified. It's for the dual battery option that comes factory in the Japanese Domestic Market version.
i put a dvd in the roof, the dvd does have a cable for turning on the dome light of the dvd. but none of the cables of the original dome would work for this.
There are only 2 wires for the dome light. I would make sure you have proper ground. And the dome light turns off by itself if the doors are open for awhile.
Reattach your factory dome light and make sure you're not dealing with a blown fuse. I'm assuming the person that's working on it has a meter. If they know how to use it, this would be a simple problem with a simple solution.
i do not have the factory dome light. actually the are 3 wires. i have test them all and there is no change when i open the door . i asume the fuse is the same for the map light and they are working.
Jhunt
