Jasonblu
Hi there,
Got pulled over for a left tail light out and time is running out to get it fixed without a penalty. Cant afford to pay a pro so I am hoping I can get a solution here.
What I did/know so far:
1) New bulb installed. No change
2) Swapped the twist in bulb housing. Fault did not follow so its NOT the twist in bulb housing.
3) The bulb lights DIM (as it should) when lights are turned on, but doesn't go BRIGHT when brake pedal depressed. (the passenger side and top spoiler brake lights do go bright though)
I therefore suspect the brake pedal switch. I unplugged the connector down there and plugged back in hoping just a loose connection. No change.
Can someone walk me through how to further troubleshoot this or direct me to a thread that goes over it - a thread search turned up nothing.
Thank you!
Jason
Thank you!
Jason
