Help- High Pitched Sound
08UrbnRunnr
Hi all-
Has anyone experienced a very high pitched faint sound inside their 4runner? The sound is continuous. It occurs with/without the radio. If the battery is on, the sound is present. I've been to the dealer 5+ times, no luck with a resolution.
I am beginning to lose my mind when I'm in the truck.
Any ideas?
08UrbnRunnr said:
Hi all-
Any ideas?
Are you sure the noise isn't coming from your engine bay? I have a high pitched whining sound coming from my engine bay. Not sure what it is.
I had a friend who had an 05 Tacoma whose p/s whined all the time. Dealer said it was normal. Owner axed why other Tacomas did not exhibit the same thing. No help from dealer.
Isn't the sub powered all of the time? I'd try pulling fuse 18 and 28 from the underhood compartment and see if that gets rid of it. In my '07 manual those are the two fuses that are related to audio. That would rule out an eletronic whine.
:cheers:
I spent some time last night climbing around to find where the sound was coming from. It seems as though the sound is coming from under the glove compartment area? There is a cover which I removed. The sound is definetly coming from that location.
What could it be?
What could it be?
Is there an amp there? Can't think of anything else offhand that would be in the area and causing a high-pitched noise.
buy a cheap steathescope or borrow one and isolate it further perhaps on both sides of the firewall.........??
Cpn2mss
