Help ID this hose
chester4Run
This hose is leaking near the back of my engine (the one with the red line in the pic). I think it connects to to the same block of metal that the little U shaped hose is on. This hose connects to a fitting that goes to another hose that goes into the dash, so probably to/from the heater core. It has split right at the clamp on the lower end and now drips coolant into the exhaust.
While I work on figuring out how to get the pic to display properly, here's a link.
https://ibb.co/jXjbAn
OK got it, the image is embedded in the next post. :)
Does anyone know what it's called, or have a part number? I'm digging through diagrams for the 3vze, but not yet finding one that looks like it has the same routing. Thanks in advance!
Testing with the image:
<a href="https://ibb.co/jXjbAn"><img src="https://thumb.ibb.co/jXjbAn/IMG_0863.jpg" alt="IMG_0863" border="0"></a>
Hose, heater water, inlet a
That is a HOSE, HEATER WATER, INLET A Your truck does not have a rear heater( I assume form your engine picture ) so the part number would be 87245-89289.
Thanks willyt4r, that looks to be the right part. I'll try to cross reference that part number if what I ordered doesn't work out.
You can just use 5/8 heater hose that the local parts store sells by the foot for like 1$/ft and brass 45° or 90° barbed fittings. From the hardware store.
Sent from my XT1635-01 using Tapatalk
Thanks, that's my backup plan. The hose I bought was $25 after shipping, so a little pricey but I decided to try it. The OEM part number is discontinued everywhere.
