I recently purchased a 98 limited with the power antenna option. Found the radio reception to be pretty bad and found that the top nut and grommet holding the antenna to the fender panel had come off and the power antenna was being held up by the antenna coax cable through the fender wall grommet. Anyways needless to say the fender wall grommet popped off and the coax cable is cut. Is it easier to get a different antenna or should I try to replace the original cable?
Any ideas?
Thanks!:thanks:
Any ideas?
Thanks!:thanks:
