Help injectors still leaking?
akdawg
I have now done this job at least 5 times???? Using new o rings each time, is there a trick to keeping them from leaking.
Snugging them up, and it starts to leak.
Help please?
Kurt
After multiple attempts you may
want to give www.witchhunterperformace.com a call. The owner takes all calls and a great person. He is the go to guy for rebuilding and flow test injectors. He could make a simple suggesting on a step you may have overlooked. If it's not sealing, more than likely its not seating properly. Worth a try.
Hope this helps......
Regards.........8sm
you dont want to use break clean, that is used to swell rubber so it will be larger than normal b4 you even try to put it in. (stay with me here folks). a light dab of oil and working them back and forth and in a circle is the best way to get them to seat properly. good luck!
I have used bot muti purpose oil and break clean
