bak3rme
Senior Member
im a total noob to electrical. so i looked at the writeup for installing hella500 but im just unclear because what i got in the box was different...
i got a set of hella 700 and the instructions werent that good.
there are 4 wires that come out of one socket.
red
blue
black
yellow
and then i got a green wire that was in a bag by itself
so i know that the black wires run from the little relay cube to both lights.
the red wire has a little C looking plate on it which i know runs to the red side of the battery terminal
the blue wire however has the same C looking plate but its only about a foot long. im confused what to do with this blue wire since its so short. it looks like it should be hooked up to something nearby.
then the green wire i have no clue, but on the instruction thing it just says it goes to my headlights high beam.
i also in a separate bag another blue wire about 1 foot long..with the C plate looking thing
then there are 2 blue wires on each set of hella lights...are these ground wires?
i just want to wire it so i can turn on my lights whenever i want and turn off whenver i want.
THANKS...ill post pics if you guys need me to of all the stuff i got and wires
EDIT** the on/off switch they gave me says that 3 wires run up to it: yellow, blue and green. but if the blue has that C looking plate on it..there is no way i can hook it up behind the swtich
red
blue
black
yellow
