squirrelchill
So I have a 99 Limited with the 3.4, I bought the car last summer with 225k and have put about 5k on it. It had been feeling underpowered and the previous owner had indicated they had overheated it. I replaced the entire cooling system. I recently began noticing white steam/smoke out the tailpipe and it lost some coolant, so I assumed it was a head gasket or cracked head.
I performed a compression test and leakdown test, and the results have me a bit confused and I'm looking for some guidance in interpreting this, the results of the tests are:
Cylinder 1 - 19% pressure lost (73/90psi) | 180 psi compression
Cylinder 2 - 46% pressure lost (49/90psi) | 175 psi compression
Cylinder 3 - 44% pressure lost (51/90psi) | 180 psi compression
Cylinder 4 - 47% pressure lost (48/90psi) | 180 psi compression
Cylinder 5 - 28% pressure lost (65/90psi) | 180 psi compression
Cylinder 6 - 26% pressure lost (67/90psi) | 185 psi compression
I know the leakdown numbers are bad news, on every cylinder the only place I heard any air pressure escaping was the oil dip stick tube, and smelled some oil when the pressure initially was connected. There was no air observed escaping through the radiator, which seems to rule out a head gasket problem. I also thought I possibly heard a leak coming from the intake manifold but it was hard to tell. I've never done a leakdown test before but I followed [MENTION=120071]mtbtim[/MENTION] Timmy The Toolman's video exactly and used the OTC 5609. Any thoughts??
