Help Me Choose an LED Aux / Driving / Off-Road Light - KC vs. Westin
I'm close to finishing up my True North Fabrication bumper and it's got 4 spots for lights - two 4" holes and two 2.5" holes.
Here's an image of a completed bumper (not my truck). I'm looking for lights to fill the larger holes that he has what looks like amber fogs:
My use is going to be primarily on dark highways when there is no other traffic around, backroads in Vermont, and occasional night time offroad. For all of that I would prefer a wider spot pattern like 30 degree or blended spot/flood pattern.
I will most likely put smaller flood lights into the 2.5" holes though, so I'm cool with the larger lights being more dedicated spot duty.
The decision basically boils down to paying more money for name brand, lower spec product with KC LZR lights at ~$260/pair or cheaper alternatives that have higher specs at $130-$200/pair. Money is not a huge concern, but I'd consider the KC LZR being the max I would want to pay for these.
Here are the KC LZR, basically the default choice.
Here is the Westin Odyssey SP. I'd never heard of them and don't know much about the company, but found them through searching around. Seem to be spec'd high.
Here is Superbrightled's, I guess house brand. Don't know anything about them other than they spec really well.
Here is the darkhorse - ADVMonster. They're pretty well known in the adventure bike community and I have one of their floodlights on my bike.
If they made them in a larger size I would order without hesitation, but in the smaller size they won't fill the 4" opening. They do spec very well, and I emailed the owner, apparently this light uses a new and very advanced LED model that is highly efficient vs. the KC LZR LED that is 8 years old.
  • URL: Model 55 LED Light Kit - ADVmonster
  • Price: $170/pair + more for switch
  • Includes: Wiring Harness
  • Size: 2.7" round
  • Beam Type: Combo Flood & Spot, 7 degree primary with spill from reflector
  • Raw Lumens: 3,000
  • Watts: 25
  • Beam Distance: 457m
Really interested to hear your thoughts and if there are others on the market that would fit my use case that you guys would recommend in the sub $250/pair range.
So nobody responded, but that’s okay. I ended up going off the menu.
At first I thought Baja designs was too expensive and didn’t look much at them because I only saw the squadron pro at $400+ a pair.
After a ton of research though I had another look at the Baja Designs squadron sport, which is $220 for the pair at 2,200 lumens each.
https://www.bajadesigns.com/products/squadron-r-sport-pair-driving-combo-amber.asp
They turned out to be the best contender for the price/features/value
What I like about them is they are 4” round, and they have a combo driver/flood beam. But their squadron series are the same base light, and you just change out the lens for what you need.
So I also bought an amber fog lens cover along with my driver/flood cover, both in amber. The lights use a rubber o-ring (i.e. they’re not permanently sealed like most) So I can experiment with the lenses and see which one I like more in that place.
I also read another post that compared them to rigid d2 in terms of waterproof ness and they were much better - see here: http://www.pirate4x4.com/forum/gene...orts-sick-fogging-lights.html#/topics/1753201
Not to say one is better than the other, but it certainly gives some peace of mind.
Anyway, I emailed Bailey [MENTION=87816]Baja Designs[/MENTION] and he hooked me up with the forum discount. Excited to get them in.
