Help me find a thing.
KidVermicious
Well-known member
I'm looking for a digital voltmeter to mount in my cab. Something like this, but with two display outputs so I can monitor both batteries at the same time.
I could install two, but dash space is at a premium.
that gauge, properly connected with a switch would be able to monitor both batteries. you would switch it to check each one separately.
There's an idea. I might do that instead of putting in two modules.
I wish I could find both on a single module though, like this:
bat_gauge-1-jpg.612683
There's a listing for that exact item on Amazon, but it's "unavailable", and I don't see that bad boy on the website for RGB Electronics either. I emailed them, gonna see what they say.
Just my .02 if you end up using 2 seperate meters,
These on ebay work perfectly fine, I've ran a Blue one for well over a year, and just switched out to a red one, and plenty of people on car audio forums run them too.
They read exactly the same as my Multimeter.
New Mini Digital Voltmeter 4 5 30V Red LED Vehicles Motor Voltage Panel Meter EK | eBay
I eventually gutted it and stuck it in the factory 3rd gen clock, just to give you an idea on the size, I don't think it would be too hard to make up some kind of mount/case to put a pair together, but I'm not at all familiar with the 1st gen dash, so I can't help there.
Think small :). There's space, but not much. Once you start talking winch controller plus aux light switches plus dual battery switch plus elocker switches, things start getting real tight.
Thanks for the input on the Ebay monitors. I may end up using one of those on a switch like Nevada suggests, good to know yours has worked well for you.
I saw that, but it's got bells and whistles I don't need. I may have found a US distributor for the round gauge - I'm still looking for details, but anybody up for a group buy?
