help me stop the start up squeel!!!
Bill_Dunnigan
I get a nasty loud squeal at start up. it can last just a second, or up to 20 seconds. it always goes away on its own. I'm not sure if its the belts or what? anyone have this issue?
Drive belts. Change all three if they are old. That should be your cure.
OEM or Bando would be the brand of belt to use.
two of them are new, one is old. Is there tension-er that could be loose or worn out? maybe its time to switch to an electric fan. any junk yard electric fan upgrades?
Before you go switching any belts out, check the tension on them. I don't know how to measure the proper tension on them, but if one feels looser than the others, tighten it. They all have tension bolts on them. A loose belt will squeal.
Change the old one then to eliminate it being the culprit.
I usually just judge the tension by center deflection; the PS belt should be the tightest with about a 1/4"~3/8" amount of deflection, the ALT should be 3/8"~1/2", and 1/2" for the AC belt.
Getting to the tensioners are a b*tch on these things. I changed all 3 belts a few months ago, I couldn't for the life of me get the tensioner right for the power steering belt. I tried everything, I just couldn't get to it well enough to tighten it enough.
But I agree, change the old one for good measure and check the tension on the others.
The PS tensioner bolt requires a short or stubby 14mm ratcheting wrench, and the ALT requires a 12mm ratcheting wrench.
I just replaced the tensioner bolt and slide nut cause mine had rusted off, and holy crap that bolt is annoying to reach.
You better have a ratcheting box end wrnech for it, because a socket won't fit and you don't want to have to remove and reset the wrench every 1/20th of a turn.
thadjay
