Help. My 2010 TE Headlights Suck.
Nick B
Member
The stock headlights on my 2010 TE are really sad .
Can someone please link me to some plug and play LED bulbs to give me an upgrade ?
Thanks in advance.
I’ve been really happy with my upgrade to ZenonDepots LED low beams. Had them now for a couple months, no issues. Nice clean lighting with built-in adjustments.
Not having any issues with pattern and such? I have been looking for an upgrade on my 2012, but was concerned about LED's in the reflector housing. However if they don't cause any problems, I'm in.
I haven’t experienced anything negative myself. You will likely need to do some beam adjustments. With any reflector style headlight you’ll never be able to achieve a perfect array & cutoff without a retrofitted projector housing. Definitely look into adjusting the beam if you go with the LED or HID swap. I had never done this before and it was relatively straight forward when following a post I found in the forums.
