econhonda
Hi Everyone. I have searched and searched, but have not been able to reach a conclusion regarding an issue I'm having.
Starting a week ago, my 4runner's brakes have suffered from intermittent hard pedal syndrome. I seem to have plenty of vacuum going to the Booster. I pulled, cleaned, and sucked the check valve. Seemed to work fine although it made a fluttering noise when I sucked air through it. Brake fluid is full. No fluid leaks that I can see.
This seems like a Booster issue to me, but it's strange to me that it works and then doesn't again with no rhyme or reason. Also, I don't hear a vacuum leak except when the peddle goes hard I hear a slight hiss from down by the peddle.
One thing I can't stop thinking about is even when the brakes seem to be working normally the peddle slowly falls under constant pressure. Could my master cylinder be bad as well? Could the Booster be fine and a bad master cylinder be causing all of these issues?
Thanks everyone.
Thanks everyone.
