Help po325/330
Davidv32
Recently replaced both knock sensors and harness with factory. Codes will not go away. 3rd time now driving me insane
Its either 1) connection at sensor and/or connector at ecm 2) sensor (but you already did this one) or 3) the ecm itself. Get the fsm - it tells how to test each.
Sometimes codes will not go away on their own, you may have manually clear the codes and then see if they return.
Bunkstaff
