SierraNevada6
I am installing the ultimate 3 inch kit on my 2011 SR5. Everything went great until I installed the sway bar relocator. The sway bar relocator moves the sway bar to a position that doesn't allow me to bolt back up one of two brackets running from the front cross-member to the housing holding the radiator. The skid plate would then bolt into that bracket, if I could reinstall it. I'm pretty sure everything is installed correctly, but the 1/2 inch move of the sway bar doesn't work with that bracket. Has anyone had that problem or know of a solution? On another note, does anyone know if the diff drop will fit without adjusting/cutting the skid plate? Thanks
