Help, tires!
Supertrooper4
Alright so i want to get bigger tires, but i cannot find the right size tire to fit without rubbing. Im stressing bc i dont want to run a 30" to 31" tire, i want atleast a 32" tire, So i want the biggest tire that wont rub. I have an 02, and i put on a 2 1/2" coil spacer lift. So please help me!!, and im game for having to put wheel spacers on if needed to fit the biggest tire.
Stock is a 265/70 which is about a 31" tire. Also use the search function as there are litterally hundreds of threads on this subject as well as a Sticky at the top of the page.
As mentioned they are taller. How to read Metric tire sizing. This has been posted in numerous threads as well as links to tire calculators but here it goes again.
265= tread width in MM(milimeters)
70= aspect ratio of sidewall height compared to tread width in a % (this case 70% of tread width)
16= rim diameter
so a 265/75/16 would have a 5% taller sidewall height than a 265/70/16.
Link to tire calculator to prove it.
Tire Size Calculator - tire & wheel plus sizing
