BlackWorksInc
Okay to clear the air on something here. The Actuator is internally pinned to the transfercase, period. What you see in the following pictures is "technically" an improperly removed actuator with part of the actuator still inside of the unit; Toyota does not want you to open those things up AT ALL and so far no one has managed to time them properly after trying to do it this way (I am hopeful that the OP http://www.toyota-4runner.org/4th-gen-t4rs/151582-4lo-actuator-rebuild-2.html has it working, but he mentioned he still needed to tinker with it, maybe he can chime in on it).
If you removed the actuator by partially dissasembling the case, you've done it incorrectly and invited some problems. Its a catch 22 now, because if you aren't experienced enough to time it properly (and so far we haven't confirmed proper timing has been achieved as of this post) then you need a new actuator and you need to tear down the transfercase to replace it, otherwise you're where you started.
Just to be clear. I'm not saying that the method in http://www.toyota-4runner.org/4th-gen-t4rs/151582-4lo-actuator-rebuild-2.html is bad, its still unproven and highly technical to make work properly; something most people and most shops wouldn't bother with because of the high risk factor. Its a possible method to repair our vehicles, but is technically "improper" according to Toyota and there's no support whatsoever if you mess it up.
