HELP! vcs is going to kill me.
oncewaspfd
I've been having problems with my '02 limited. The vcs is kicking in from a dead stop on dry pavement. It doesn't kick in when I'm doing a rolling start. It happened a couple of times when the roads are wet, but has gotten worse since winter cold has set in.
How does the vcs actually work? I changed the fluid in rear diff this fall to synthetic. Would this cause a problem? I want to put the vcs switch in this spring.
VSC=Vehicle Stability Control
WHen the Check Engine light comes on, the VSC/Trac light(s) are also set, which turns these systems off. This is a self-preservation mechanism, in case the reason the Check Engine Light is on can harm or effect the VSC/Trac systems. So- fix the reason why the Engine Light is on, and the VSC/Trac system(s) will come back online.Found this explanation online. It summarizes the check engine light and VSC Trac light issue pretty good.
When the Check Engine light comes on, this is the on-board computer's way of telling you it sees a problem in one of the monitored systems. Unfortunately, there are litterally 100's of parts and sensors monitored in various systems, and to take a "guess" as to which part/sensor in which system is faulty, is virtually impossible. However, if you are not experiencing any drivability issues such as skipping, stalling, shifting problems, etc, then more than likely, the problem is going to lie in the EVAP (emissions) system. Very commonly, this could be a faulty, loose or missing fuel cap or even putting fuel in while the vehicle is running. Check the cap for any cracks in the rubber o-ring on the underside. Check the fuel filler neck for any signs of chips or debris. Check under the vehicle, around the area of the fuel tank and the EVAP canister looking for any vacuum lines that have dry-rot cracks, holes or loose/missing connections. If these all check out, then the best thing to do at this point is to have the "p-codes" read from the on-board computer. These p-codes are what is used as a "starting point" for the diagnosis and will tell which part/sensor in which system has the fault. There isn't a Mechanic on the planet that can tell you what is wrong with the vehicle just by "looking" at the Engine Light. Every single Mechanic's first course of action WILL be to obtain the p-codes. Once you get these p-codes you can more accurately and efficiently diagnose the problem and then make the repair. You can have these p-codes read FREE (except in California) at any local "big chain" part store (ie. AutoZone, PepBoys, Advanced, etc).
I don't see where the OP mentions he had a CEL. It sounds to me like OP might want to chop off the lead foot. VSC would kick in whenever the tires lose traction to prevent the rear end from breaking loose and possibly causing a rollover.
VSC safety technology
Check this out
http://www.toyota-4runner.org/3rd-gen-t4rs/102406-abs-vsc-trac-disable-master-thread.html
There is no check engine light on when this happens. I don't have a lead foot either. The tractin control doesn't kick in when the rear end slips on a the white crosswalk line that's wet. The engine boggs down when it happens. I then let off the accelerator then trie it again.
I have an 02 also and I'm putting the switch in to disable all three( abs, vsc,and trac) in the next couple weeks. Very easy mod from what I've read.
patnewton
