Help w/ Front Differential Fluid Change
Well, they are a full shop and they have spares on hand.. so they just go at it. Plus, things get much easier on a full rack where you can literally stand under it.
Mechanic shops just have EVERYTHING.. and can just whack at it till it comes.
Well, I too have access to a well equipped shop with frame lifts, air tools, you name. Think I just didn't have the guts to start drilling into the drain bolt and not being able to get it out.
Regardless, more than happy to pay $29 dollars for someone to do the job that would have probably taken more of my time.
Used Mobil 1 Synthetic Gear Lube LS 75W-90 front and rear.
Bet anything they used a chisel. If yours was so bad they may have used an air chisel.
delislerebecca
