Help ! weird A/C Vents Problem
nyc4runnin
I have the strangest problem with the 2 driver side vents, I turn on the AC and its cold coming from all the other vents but the 2 driver ones. I usually leave all the other ones closed cause i'm the only one in the car 99% of the time. What could be causing this ? If I put the fan on high and all vents open, the driver ones still are blowing out alot less cooler air. I dont think its clogged cause it blows the same amout of air as the other vents do.
hmm interestingly if I put it in auto mode, the temp seems to get cooler, but still not the same as the passenger side or back. :-(
