Berty_K
Member
Recently started hearing a rattle at low RPM, near idle. Intermittently hear it when I’m starting from a stop or I’m in drive and stopped.
Sound has a bit of a metallic sound to it.
Crawled under my car and checked for any loose heat shields and hangers, but couldn’t find any.
Started knocking on the exhaust pipe and found the sound seemed to be coming from passenger side of the exhaust, near the front and rear catalytic converters. No loose heat shields or loose mounts.
Looking closer at the joint between the two passenger side cats, there seems to be a gap (picture below). Is it plausible that the gasket that goes between the two sections of the exhaust disintegrated and is causing the rattle?
Hoping the gasket is the culprit. They’re cheap and should be a relatively simple fix. I don’t think my cats are the cause of the rattle. I don’t have any dash lights (cel) that would indicate my cats aren’t functioning correctly.
