Help with fan removal on v8
darkgun82
Trying to get fan off for alternator swap and one bolt left but pulley turns and can't loosen bolt. How do I keep pulley from spinning?
Two ways (or more), strap wrench on the pulley if you have, or what I have done also is refasten a nut on the fan pulley and then put a 12mm box wrench on it with an extension bar (so it "locks" into place on the frame). Then I undo the stuck nut with another 12mm wrench. Then I undo the 12mm that was "locking" the other in place as it usually comes off a lot easier than the stuck nut, so holding the pulley by hand is enough to undo it.
Sorry, hard to explain, I'm changing the radiator on mine this afternoon, I'll snap pics if you don't get it later today.
I ended up doing that ask10 since I didn have a strap.
Not sure I want to watch Derek, especially after taking 15 minutes to get the fan off :boom:
Make a tool like this to hold across the bolts. My dad made this and it works slick.
Philthyphilthy
