olsen_karl
I'm in the middle of installing FJ Cruiser springs (Moog aftermarket ones) on my 4Runner, on Bilstein 5100s.
I'm trying to set the front springs at the 1.75" notch on the Bilsteins, because I have a winch + bumper (aluminum) + large Diehard/Odyssey battery weighing down the front end. It's a V6, but I estimate that I have about 110-120# extra weight on the front end, vs. a completely stock 4Runner.
The "no spring compressor" method is not working. I need to be able to compress the coil about another 1.5" to be able to get the assembly in place. So, I stopped, and am going to borrow a coil spring compressor tomorrow in hopes of finishing the project. (The cheap coil compressors I have are too thick to be able to fit in between the coil wraps.)
Searching online, I am wondering about the coils I got. My Moog coils have 10-11 wraps (depending on where you count), which is several more than the stock 4Runner coils, though the overall unloaded length of the Moog FJ front coils is only a little bit longer than the stock 4Runner front coils. Anyone have a pic of the stock FJ coils and can confirm the number of wraps? I'm a little concerned that I may not have the correct coils.
I found this photo while searching, that supposedly shows stock take-off FJ coils. It shows only 8 wraps for the front:
^^ The green/gray and green/yellow paint dabs are confirmed here as being the correct paint markings for FJ coils:
http://www.toyota-4runner.org/engin.../83113-help-color-code-fj-springs-please.html
So, a couple questions:
1) Anyone have FJ coils laying around, or installed on their 4Runner, and willing to go take a look for me? How many coil wraps do you have for the front coils?
2) Anyone installed the FJ front coils on Bilstein 5100s at 1.75? Did you have to use a spring compressor? If not, how did you do it?
