help with headlights
statechamp02
i just got my piaa super white head lights but now i need help installing them how do i remove the old headlight bulb if any one can help me that be great thanks
Grab the base of the old light and pull lightly, or wrap a towl around the bulb. Also, do the same when installing the new ones. If you touch the new/old bulb, the oils from your hands will cause them possibly explode when they get up to temperature when turned on. Not a tough task, just take your time.
What type of bulb is it? ie: 9005, H4, H11, etc.
Some bulbs have a cap that you just twist to unlock it, others have a rubber boot that needs to be removed to access the metal clips that hold the bulb in the housing like with a H4 bulb. I am unsure of what the 96' has.
^ most liekly 9006 bulbs or something that'll twist out of the socket and then pulled right out.
