Help with inside lighting issue
RedHottG2
Guys my interior cluster lights seem to be a little weak and also my radio lights are completely gone. My dome light seems to be ok. Are stock interior lights on 2000 T4R normally weak or are they bright ? My dimming switch is turned all the way up. All other lights seem to be OK including headlights/fogs. I did notice my door panel window switch light is very weak and and so is the passenger side. There are no lights on for the door lock switches, is that normal or should they be lit up also ?
Everything looks normal. Have you had the truck for a while to notice a difference? The lock switch doesn't light up. The radio should light up and since it's not there's nothing you can do about it except replace the radio. I had the same problem. There are 3 bulbs that light up the dash cluster. I replaced mine with 3 hi powered white LEDs which I love. Look in the reference part of the forum for bulb sizes and suggestions. There's probably some bulbs burned out that you didn't even know where there ( ignition ring, cig lighter ring, ash tray lite etc) I warn you once you start replacing these bulbs you probably won't stop until every bulb in the truck is replaced. Good luck!
