Help with picking a mechanical buffer/polisher
You have to read up on the G110....it actually has a new feature where it will maintain speed as the load increases. I've used it and it works very well. I'm not sure about the forced rotation thing you're talking about, but I tried my best to stop my machine with a loaded up pad and it just kept going. Actually, it barely even slowed down until I pressed much harder than I would when buffing a car. So it seems pretty good to me.
You are correct, it is very hard to stop the G110v2 and the GG. That is because of the power of these machines, but they do not have forced rotation. They are very close in power. The only worth difference is the warranty. Again, they are both very good machines and a better bang for the buck then the Flex.
Koz
In my opinion, ' more power' is a poor choice for picking a da, within reason. I use a PC, and have used others. Really any machine above the $100 mark will be fine. You want something that is smooth and comfortable to hold. Neither you nor the machine is doing the actual work, so there should be no reason you are pressing hard enough that you need more power.
As far as products go, I've specifically used menzerna products and they are amazing. For black and red cars, I recommend blackfire products, they are designed for those two colors. In general, klasse aio is a great product, but I use p21s as a final layet instead. Here's a secret, p21s (for cars) and s100 (for motor cycles) are the same product, but s100 is cheaper and easier to get. Your local harley dealer probably has it in stock.
Not to take people away from this forum, but there is an awesome detailing oriented forum called autopia you may want check out.
Sent from my Nexus One using Tapatalk
The machine itself will apply approx 7 lbs of pressure. For nice results you need to keep the pad flat. This will take approx 10 lbs of pressure. When you need to correct color or remove surface defects you will need to apply up to 20 lbs of pressure on the pad.
All of the first gen polishers (PC, Meg and GG) have been redesigned with more POWER because they would stop when the pad was saturated with product and/or more pressure was applied. You would need many pads and have to change them frequently.
The power of the machine dictates the amount of time required to achieve set results. It also can limit the degree of correction or defects that can be fixed.
Koz
Speaking strictly from my own experience, an orange pad on a porter cable set to 3 with an aggressive polishing compound is more than enough to remove swirls. I haven't burned through any clear coats, but one could pretty easily with the above setup.
If others have found that any if the good da's stopped while using them, who an I to argue with that? It's just never happened to me.
Koz
I need to correct my comment. The Groit's is almost twice as powerfull as the Meg's.
Porter Cable 7424XP
4.5 AMP
500 Watt Motor
5 pounds
3 Year Limited Warranty - 1 Year Free Service - 90 Days Money Back
Griot's Garage Random Orbital Polisher
7.0 AMP
850 Watt Motor
5.5 pounds
Griot's Lifetime Warranty
Meguiar's G110v2
4.2 AMP
430 Watt Motor
5 pounds
1 Year Limited Warranty
Koz
So the real question is this-- how much power do you need? Like I said, I'm unable to stop my machine, even under the worse possible conditions....it just keeps going and going.
LOL, it's not like I'm using it as a disk sander to refinish my front door.:trophy:
Koz
I don't know much about the others, but the V2 Megs machine was designed with "cruise control"....basically it will respond to increased load/pressure and keep the pad speed constant. So I don't really think it needed more power, it just needed a way to adjust to increased loads to maintain speed.
I've heard nothing but good things about all three. No complaints of stopping (not like the first gen). The difference between them as far as performance is the time savings. GG needing less time. Also, if someone is in the market the GG is less expensive, has more power (faster results) and a lifetime warranty.
I still recommend the Flex, if you are willing to pay double.
Koz
Fair enough...but another thing to consider is safety. What I mean by that is when someone who is new to polishing a car with a machine....I'd always recommend a machine that can help keep them out of trouble. That's one of the reasons why I purchased a DA instead of an orbital.
A DA is orbital, you mean circular/rotary.
Koz
As for products, I use Klasse All-in-One (AIO) and Klasse High Gloss Sealant Glaze (SG). The longevity of the combination of AIO and SG is great.
Autogeek.net has 20% off over $95 with coupon code: fall20. Good through 9/24/2010 midnight ET.
Unfortunately, it doesn't apply to buffers and a few other items, but still could lower the total tab for other detailing items like a foam cannon. :bravo:
So tonight I pulled out the Visa and made a purchase from autogeek.net.
PC7424XP W/LC 3.5" & 5" back plates
LC 5.5" CCS pads 3 Orange, 3 white, 2 of each of the following colors gray blue and red pads.
then 1 of each color pad already mentioned of the 4" LC CCS PADS plus a yellow one
6 pack of cobra miracle MF towels, artic white edgeless MF towels
Guzzler tripple kit (the waffle weave mf towels)
Daytona Speed Master 2 brush combo
DP polish pad rejuvenator & foam pad conditioning brush
2 grit guards 1 red other blue
8oz optimum care care pack (compound II, Polish II, finish polish)
DP TPP 105
DP Aquawax
I took advantage of their 20% off and free shipping saved $80 and whatever shipping would of been. GT $448.06
DP TPP 105
DP Aquawax
Time to get busy!
Koz
I don't have a back that could deal with a week of hard work required to polish a truck. God bless you!
Koz
:confused: But you can use some buffer to do the hard work? Hand buffing is like Karate Kid (wax on, wax off). You don't have to use your back. :)
Just standing too long and I'm in pain. I have to use a mechanics stool to do the sides of the vehicle. The Flex really helps by cutting the time required, love this machine.
Koz
Koz
I guess everybody have their own back issues. Mah bad.
Awesome. I'm glad you were able to take advantage of it.
I like Autogeek, they ship quickly and they pack the items well. I got my stuff using the cheapest shipping method in a week on the opposite coast.
I agree, it's where I get all my supplies.
Koz
AndiGarage
