help with project
there is a suspension sticky at the top of the 3rd gen section... u should check that out bc it should be able to help with most of ur questions about wat 3" suspension lift to get
So I take it you aren't planning on wheeling your truck. The only thing you can do to get a 6" suspension lift is adapt a drop bracket one from same year Tacoma for the front and then you are on your own for the rear. The factory link arms will not like the angles in the rear and would require custom springs or LC springs with spacers. Ideally you would have custom rear links made with springs. Or convert to a leaf spring set-up. Do a search on here and you will find someone that did the 4" Pro-Comp drop bracket up front.
