Help with Wiring
PedsFlightRN
I got my Jaos lights and I have them all wired according to instructions. I tapped into the green wire of the parking light wire harness as stated in prior lighting write ups. I can hear the relay working when I push the button, but no lights. Did I tap the wrong light. Not sure what else to do. Thanks in advance.
Leslie
I would make sure there is actual contact at the tap, the wire is a thin one. I ended up carefully cutting away some of the insulation on the wire.
Okay, well it was the right wire. Whew--thankfully! I would hate to mess up the wiring. I just hadn't grounded it properly. I had grounded it, but I guess it didn't like the choices I had made. So now they are working perfectly!
