Help!
Ghost Rider
Added the Compass/dimming mirror over the weekend, and now the auto up/down on the driver's window doesn't work... So far everything else appears to be working...
I tapped into the Brown/red wire as per instructions, and used the grounding bolt nearby...
Any thoughts??
Did you disconnect the batter? I think I remember someone posting this same problem. I think that the programming got reset, but check your Manual. There should be instructions to reprogram the auto up/down. Or do a search on the board...
Did the search, and remember a post like you said... I'll re-search and dig through the posts again...
If nothing else, I'll RTFM tonight...
No need bro. I had to drop off my mail in the box anyways so I grabbed the manual out of the car. Here are the instructions out of the manual.
1. Push down the power window switch and lower the window halfway.
2. Pull up the switch until the window closes and hold the switch for a second.
July
July
Thanks for checking!
July
Worked like a champ!
Thanks again!
