Noloc
Ok, so here's the issue. I bought a set of custom projector headlights from a fellow member with a HID kit. I installed the headlights along with the HID kit and now my Highbeams are constantly on when I turn the low beams on. :
I've been forced to removed the plug from the highbeams temporarily until I can find a solution. There are two ballasts, two blubs, 1 wire harness. There's one ground and one power connection. The wire harness plugs into each stock low beam connector (which I'm assuming is how each relay is switched to turn the HIDs on). Each lead to both headlights is fused with a 25A fuse. Please, someone give me some advice here.
