HID Lights (Low Beams)
  • Thread starter Thread starter 2004Yota
  • Start date Start date
2
2004Yota
Guest
I installed an aftermarket HID light kit for my low beams this weekend. Driver side auto-down for window no longer works. HID Lights by www.pilothid.com. Widow still operates up and down, but "auto" feature no longer working. I'm willing to compromise, if there is no solution. However, has anyone experienced this problem with the install of aftermarket HID lights? Any solutions? Light intensity is great! Blows away the PIAA Halogens I installed last winter.
you need to reinitialize the auto feature of the window after disconnecting the battery.
check your manual for instructions
Pull up driver's side window button. Hold up for 5 seconds. Push window button down. Works like a charm! Thank you! How do you like to Toytech lift kit? It looks sharp!
I think it is made of very high quality materials and I like the fact the rear uses OME springs and not polyurethane spacers like most spacer kits. The ride is pretty much stock with a little bit of stiffness in the rear due to the heavy duty springs but it doesnt bother me. Low cost!
