higher idle after long drive
masphx
Just got back from a weekend in Vegas. Truck was great there are back. It is about a 5-6 hour drive as I did not push the rig. When I got back into phx traffic at redlights I noticed my idle was around 1100 when clutch was in neutral. When I got home left it running for a min and the idle did not go down. Is this something I should be concerned about? Btw rig has 198200 miles on it. Normally rig will idle 500-700 rpm.
MIL on? Could be a vacuum leak? You can use a spray bottle with water to identify a leak by misting over the intake while idling... If it bogs the engine in any way that's a sign of an intake leak. Another possibility is if the computer thinks the operating temp is too cold and it's still in open loop... Is the temp gauge reading normal?
No cel. I even have it hooked up to an ultraguage. Besides the high idle nothing out of the ordinary that I can tell. When I drive it again will update this post if it idles high again. Maybe it was a fluke after a long drive?
One thing you can do is check to see the if throttle valve closes all the way at idle. On mine, the valve didn't close all the way, and I could, with moderate pressure, force it to close that last couple millimeters and then idle would be normal. Just another thing to hopefully rule out.
True that I keep forgetting these trucks use a throttle cable
Rialm
