Highest Mileage 4th Gen?
My 07 SE V6 2wd has 213k have done nothing but brake rotors, pads, plugs, fluid changes and transmission flush, even have the XREAS, and zero rust as its never seen snow here in California maybe why never had to deal with caliper replacements...my 97 4cyl 4 speed i ran through 2 transmissions and burned valve at 335k, this one has been more reliable..
06 v6 sport
135k
I have changed front calipers and valve cover gasket (oil on spark plugs)
Had to remove catalytic converter cover as it was rattling
Also about every single interior bulb has died and needed to be replaced
Replaced passenger front headlight assembly as it was holding moisture
Previous owner had to replace 2 door lock actuators
I would bet it is frame rust.
I second that. I see lots of people using them as family vehicles in the more northern areas I've been to. Not everyone takes care of their vehicle like enthusiasts do, especially the underside. Mine was previously used as a family vehicle in a more northern state. Not too crusty underneath and I make sure to wash after salted roads, but I plan on doing a full POR15 undercoating this summer to prolong the life.
Woohoo!
Sent from my ONEPLUS A5000 using Tapatalk
My 2005 only has around 174,000 miles. I keep thinking I need to replace it but it seems that another 100K will be easily doable. No frame rust. It has always been a Colorado vehicle that sees some mag chloride but is also garaged and the undercarriage washed.
My 2005 SR5 has 150,000 miles and not a speck of rust on the body.
The under frame has mostly superficial rust.
A few "flakes" off the front cross bar right after the radiator - but this bar is over an inch thick
I sprayed it with Corrosion X a few years ago - and it turned black
Been garaged and driven two blocks from the ocean here in the Bahamas
06 v6 sport
135k
How much did the valve cover gasket run you?
2008 sr5 v6
2008 SR5 V6..
Bought with 160,000 four years ago. Just hit 245,000 miles
Front ball joints at 210,000
ABS sensors and a harness on the drivers side....that was the problem
pass. side rear wheel seal at 210,000
numerous exterior bulbs
plugs at 190,000
LED upgraded interior lights...makes the world of difference
It lived in Maine then moved to Montana when I bought it.
Been great and plan on keeping it but wouldn't mind a 2020!
2006 v8 with 232k
This is the exact configuration that I'm looking for after I get rid of my Touareg. Love seeing all of these higher mileage 4runners. Definitely makes me feel more comfortable about picking up a 150k mile + 4th gen as a daily driver!
Just rebuilt a blown 2003 with a friend of mine. Truck has 330K, “new” motor installed at a local shop is 156K. Truck is a 2003 Limited 4WD V8, really the only place the body shows it’s age is the leather, and I just had to replace the radiator as it was ruined when the old motor overheated.
2008 SR5 V6..
plugs at 190,000
Fellow Mainer here. Kudos to keeping ur 4runner alive to 245
AndiGarage
