HiluxSurfGuys 99 (Slow) Hilux Surf Build
HiluxSurfGuy
New to the forum and a new Toyota owner, though have had yotas in the family since I was very little. In May of 2014 I aquired a freshly imported 1999 Toyota Hilux Surf, SSRX Sub-Model. It has the 2.7L 3RZ (yes gas engine). Bought it completely stock with 121,xxx km's. It was originally from Tokyo and I am completely in love. So many cool little JDM aspects to it and it honestly gets all the looks. I have plans for quite a few mods but will have to see where funding takes me as I am still in school.
How she currently sits (October 2018):
(Trail shots with 37s coming soon)
Here are the main things (that I think are of actual value) that have been done to the truck:
- Re-geared to 4.88s
- Rear axle swap and Toyota E-Locker install
- MCM Fab Long Travel Kit (Packaged by SRQ!!!) with ADS coil-overs
- McNeil Fiberglass Fenders
- Dick Cepek Fun Country's 37/13.5/17
- Smittybuilt 9500lb Winch
- Rear drawer system
- Double din switch panel (Surf's are triple Din)
- Front tube bumper
- Non-Center Diff-Lock Transfer Case Swap (there's a long story with this one)
- Manual Hub Conversion
- Transmission Cooler, fan, and Gauge
- Tundra brake upgrade
- Skids and Sliders
Mods/ Additions:
Performance and Drivetrain:
- Yukon 4.88s
- Toyota E-Locker Housing swap and install w/ Low Range harness
- 231mm Tundra Brake caliper, rotor, and pad upgrade
- New Radiator
- Soronan Steel Rear extended brake line
- Bosch Starter Motor
- B&M 70264 Transmission Cooler
- Pro-Comp 7" Electric Fan to accompany Transmission Cooler
- Rear Extended Diff Breather routed to gas fill door
- Non-Multi Mode (Fully Mechanical) Transfer Case swap
Lighting and Electrical:
- Blue Sea Accessory Fuse box and Relay setup
- VIAIR 400P compressor hardmounted as OBA in rear cargo space
- Suzuki Inclinometer
- Transmission Temeratutre Guage
- Midland 4001 CB Radio (Removed)
- Baofeng UV82 Handheld VHF Radio
- PIAA 520 mounted on each CBI Ditch Bracket (Removed)
- 12" Dual Row Spot/Flood Mix Cree Light Bar mounted on the grill (Removed)
- 41" Curved Dual row Spot Phillips bulb Light Bar mounted above wind shield (Removed)
- 2x 4" Dual row Flood Cree Light Bars mounted on roof basket as Reverse Lights (Removed)
- Led Front Turn Signals to replace factory signals when bumper was chopped
- Red Led bulbs for Rear Plate
Exterior:
- Satoshi Grill Mod with 12" light bar mounted within it. Used a "Toyota" logo from a Camry (Removed)
- Curt Extended Roof Basket (two extensions together for full roof length). Also created custom brackets and feet to achieve lower profile. (Removed)
- Homemade low-profile "unistrut" roof platform with Fairing
- Front wheel well lower body chop
- Custom Flip Down rear tire carrier (Removed)
- U-Haul Trailer Hitch
- OZ Trail Awning - 2.5M
- Homemade CB Antenna steel mount on Rear Break Light (Removed)
- Second CB antenna mount off of ditch brackets (Removed)
- Removed Running Boards
- Major trimming of factory front bumper and removal of lower valence
- Minor Fender trimming
- Redline Hood Struts for automatic opening! [​IMG]
- McNeil Racing 4” Fiberglass Fenders
Armour:
- Bud Built Front and Belly Skid Plates
- Custom front tube bumper and front rad skid plate.
^ Winch is Smittybuilt XRC 9500
- TG 67" Sliders
Interior:
- CoverKing Fitted Seat Covers (Red + Black)
- Cargo Area Storage System. Homemade and custom created for the truck. Also has a extra storage box build to match and subwoofer box built to match secured on top
- All Speakers replaced with Pioneer Brand
- 10" Sub in Sealed Box with Amp mounted on top
- Kenwood single din head unit
- Homemade Double Din Switch Panel mounted below deck for OTRATTW rocker swtiches
- Cargo Roof Net attached to headliner
Interior Lighting:
- Led Map Lights
- Red Led Strips as Footwell lighting
- Converted all Cluster, Gauges and A/C Control Bulbs to Blue Led's
Suspension and Tires:
- 4x 37/13.5/17 Dick Cepek Fun Country's
- ProComp 17" Aluminum Wheels
Body Lift:
- 1" ToyTec Body lift
- 1" ToyTec steering shaft extension
Front:
- MCM Fab Long Travel Upper and Lower Control Arms
- ADS Coilovers
- Extended Break Lines
- Limiting Straps
- Tie Rod Extensions
- Total Chaos Spindle Gussets
Rear:
- OME 861 Coils
- Bilstein 5125s with special factory ordered stud top and special valving (Removed)
- Tokico Black Landcruiser shocks
- ToyTec Panhard Drop Bracket
- Homemade adjustable panhard bar
- Parking Brake bracket extender
- Adjustable Upper and Lower Control Arms
- Soronan Steel Extended Break line
Major Maintenance Jobs:
- Complete Intake clean-up. Cleaned all build up and replaced all gaskets from the airbox to the valves.
- New upper control arms, bushings and balljoint
- Used (Off of a Tacoma) Lower control arm with new OEM LBJ and Red Poly Bushings
- New Brake calipers with OEM pads
- Valve cover gasket and major top end cleaning
- New OEM Spark Plugs
- New windshield
- Rear wheel bearings, ABS ring gears and axle seals
While this list pertains to a lot of cheaper Mods, I have a large list of things that I am wanting to tick off, but being a University Student sucks for funding! :p
Places the Surf has been:
- Oregon Dunes and road trip all the way to San Fran!
- Poison Mountain, Near Lillolet, BC
- Almost every trail in the Sea to Sky region between Vancouver and Whistler
- Lots of other trails around BC and Greater Vancouver
This is the day she came home. So clean...:
Please feel free to ask about any of the mods I have written in the list above. I have pictures and such for most of them.
More Pictures
Here are some more pictures of the Surf exploring (sorry some are so big, not really sure how to do this whole forum post thing completely yet):
14888862031_b1e1d3ed42_o_zps9d2fdd3e.jpg~original
IMG_4849_zps14670038.jpg~original
IMG_4986_zps93f57c73.jpg~original
Nice!!
Any inside shots? Is this a JDM version of a Limited?
I forget the SS**** designations
Looks like it has grey (leather?) interior.
Nice!!
I have a few pictures of the interior. Ill go take some more though and post them up. It is the Limited version, as I got the limited A/C controls and such, but I did not get leather seats, just this ugly Blue/ Grey cloth material that just spoke old and outdated to me, thus seat covers. Ill grab some pics for you.
Edit**: Interior Pictures:
IMG_5265_zps26590172.jpg~original
IMG_5270_zps23bf8207.jpg~original
IMG_5273_zps61ab828d.jpg~original
IMG_5266_zpsd703f8ed.jpg~original
IMG_5277_zps895d9e5d.jpg~original
Looks real good, bud! I can't believe i haven't bumped into you on the road yet since we both live in the North Van area.
Nothing compared to yours at all, but I figured I would get a thread going before I start doing anything big. And it may be because I am living out near UBC right now, but I am on the North Shore all the time. We have a really short and easy run this weekend btw, heres the link if your interested: https://www.facebook.com/events/1586621174899632/?ref_dashboard_filter=upcoming
Ahh, that's interesting, i might just make this trip idk...we'll see as the week progresses.
Yea they are cool. I have looked them up online but cant find out any info about them. Kinda makes things annoying!
By the looks of them, I think they're the Victron Ziga by Jaos. I'm not 100% sure, but I think they were a factory option on some Hilux's. I would love to get my hands on a set... I want to make my 4Runner into a Hilux replica with the wheels, rear spoiler, and fender mirror since it will be more of a beach/surf truck than anything else but don't want to be a poser haha
They are actually called "Galaxy of Max" actually, but I dont remember who by, if i remember Ill take a photo soon to post up the info.
Definatly JDM 3pc rims. Are those 16"? Most JDM rims came 15x8. Rarely they came 16x8 flavor. I had a set that came from up north of You off an HDJ81.
If You ever decide to sell those monsoon window covers, I Would gladly take them off your hands. I can also take them off for You so it doesn't get damaged.
Yea they are 3pc for sure, I know that and yes, 16" I like them alot. Hope to keep them when I finally get some MT's.
And, I like them a lot, dont plan on selling them anytime soon, plus you would have to make a trip all the way up to Vancouver!
Reverse Lights
As mentioned in the mods list, I have installed two 4" Dual Row Cree Led Bars in my basket for reverse lights. They are not hooked upto the tail light/ transmission wiring as I cannot honestly think of any time where I would want to use them on road and also I want them to be able to use when not in reverse (Hilux Surf has the nice little JDM backup beeping). Anyways, here they are installed:
10486455_4823153954868_1378812486473972164_n_zps12348b3e.jpg~original
1512466_4823156034920_496043561657951924_n_zps1fa194ee.jpg~original
They are very bright, great on the trail at night!
Philthyphilthy
