Hit a large animal in our 3rd gen T4R....Off-Road Build.
howdy
Hit a large animal in our garage queen 99 T4R 5sp w/locker and low miles: (full coverage pay's off)
Insurance is flipping the bill, decided to go for an off-road build instead of cashing out of the truck....daughter is now driving the truck and getting tons of thumbs up from local wheelers :-/
The Build:
- Outdoor Logic Front bumper
- Outdoor Logic Sliders
- Toytec Coilovers / OME medium springs w/bill's shocks
- CBI Off-Road Rear 3rd gen T4R rear bumper
- Kuat Vagabond Rack on the roof
Possible changes in the near future:
- Black wheels of some kind
- RTT on the roof (might not want to put a bed on it while daughter is driving it:-)
- Heavy OME springs in the rear, dial in front coil's to match
Before:
654afe25.jpg~original
Process:
7f6da28e.jpg~original
DSC_0165.jpg~original
E4283FD3-7A70-41DB-B04C-E133890D0CB5-198-0000000F50E24608.jpg~original
After:
EE014E59-D414-420B-82B0-95B67378C175-1566-000000DBABDA6248.jpg~original
F28DE5B1-1059-4E76-96CA-81CBF536872C-1566-000000DBC043742E.jpg~original
That bumper looks a bit more animal proof. :) Check out Method Race Wheels for black wheels....they make some nice stuff, I just got these for mine:
IMG_6595.jpg~original
Nice, glad to see you kept it. What's the story with the pick up?
I like those wheels posted, checkin into them.
No story, its an original 81...I have quite a few 80's trucks:
This one has a very long story, put over 250 much deserved highway miles on him over the weekend (been setting around for a while)
Cruiser control @ 80mph :-)
4ABE5FDA-914B-4D9C-96A9-1FDE270E5116-663-0000004905761D21.jpg~original
that is one sweet early Toyota (both the tan and the red one)... I would love to hear the story behind it if you want to share it... Looks like a beast!
Love the white 4Runners... yours looks really nice - I need to find some '99+ headlights...
My last car was totaled last month because I hit a deer. That is how I came to this site and ended up with my first new (old) runner. I was going to get a grille guard but after researching here I decided not to get one since the majority says that they cause more damage. I have been eyeing the ARBs. They are so expensive though...Your runner looks badass now...I'm jealous:dammit:
What kind of animal did you hit?
Grumpy is the trucks name: Bought the red 83 longbed from the original owner, he bought it brand new in 1983, started this build many years later to the tune of approx 35K++, it is original paint..that's about it for originality though..:-) Nobody has wheeled this rig yet, it had the 4wheel camper in back since build, more of a show / expedition rig.
Engine
Professional built Chevy V-8 small block 400 Stroked (6.7 Liter 406) estimated 400hp with only 14K miles. Rods are longer than stock at 6-inch length. KB performance Pistons, total seal piston rings, ARP head studs, Fel-Pro intake manifold, BLP two piece timing cover, Streetdampr performance harmonic dampers on crank, Edelbrock Pro-Flow Multi-Port Sequential Fuel Injection has keypad in cab for adjustments on the fly. Trick Flo aluminum cylinder heads. Custom Erson cam shaft. Crowler Roller lifters and roller rocker arms. Evans waterless NPG+ coolant with total bypass thermostat. Power Steering. Air Conditioning. R & M heat exchanger hot water shower system. Premier Power welder and power supply with 160 AMP alternator, Tilton High Torque Starter. Engine temperature runs cool (198 degrees with a 195 bypass T stat). Headman headers tight fit with heat coat, Auto meter Electric fuel pressure, auto meter air/fuel ratio monitor, audiovox electronic cruise control, MSD engine knock alert sensor, Jacobs headlight brighteners,
Transmission and running gear
NV-4500 Dodge 1 ton 5-speed manual transmission with 0.75 overdrive and 5.61:1 first gear. Dual Toyota transfer cases with two shifters, front input shaft heavier 23 splined for torque. J. P. Eater adapter and 2.28:1 gears front case, 4.1:1 gears rear case. Final crawl ratio is 215:1. Dana 60 rear axle, Moser 1.5 inch 35 spline axles. 4.10:1 Dana gears, ARB air locker, Rear disc brakes with E brake, Long traction bars allow for articulation. Rock sliders are solid and the entire truck can be high lift jacked frome either side. Toyota stock front axle with Tru-Trac gear proportional locker, disc brake upgrade with Land Cruiser vented rotors and 4-Runner big caliper disc brakes. Toyota Land Cruiser brake master cylinder and clutch master cylinder. Custom-made National Springs on all 4 corners. Rancho 9000 5-way adjustable shocks. Front and rear sway bars with quick disconnects. Front and rear tuff truss front part # 90001, rear part #90002, NWNP rear auxilary gas tank, FJ80 land cruiser vented, rear disc brake kit by TSM import power brake booster, wilwood adjustable proportioning valve.
Miscellaneous
Renuel custom made front bumper ¼-inch steel and ½-inch mounting. Warn 8000-pound winch with dash control switch.Hella headlamps. Hella Rallye 4000 mounted on bumper, right Corning, left Euro driving. Hella fog lights mounted within bumper(all lights are wired professionally throught factory light switches and are wired through Jacobs electronics headlamp brightners). Hella twin trumpet air horn mounted under bumper. Renuel rear bumper ¼-inch steel and ½-inch mounting. Custom rock skids to protect body between tires. Stock 16 gallon gas tank and 13.5-gallon gravity flow to main tank under the spare tire. Audiovox Electronic Cruise Control. Hand throttle on transmission shifter. Diamond Liner spray in bed liner. The custon red camper shell comes with the truck while the slide in is not on. Has dual Optima batteries mounted in the bed. Has dual marine battery switch so when running the welders or the winch you can use optimal power from alt and both batteries. Truck also has 6 under chassis mounted lights for off road use that are great.
P3171174.jpg~original
__________83Truck007.JPG~original
SICK build! Incredible work put into all this, how do you find the time and money to do all of it? Thanks a lot for sharing the story behind it, I thoroughly enjoyed learning more about it... That would be a dream truck to own, for sure.
Thanks Farmerjon...fun truck for sure, I miss the camper that was in the back. was an awesome man cave. sold it to buy a larger camper for our ford F350, mistake,,,,,we never have time to camp.
It now sits with an RTT in the back.....don't think I will use it though. Debating on selling this rig in the near future.
DSC_0368.jpg~original
DSC_0367.jpg~original
DSC_0366.jpg~original
DSC_0365.jpg~original
DSC_0364.jpg~original
a776eceb.jpg~original
You must tell me first if you ever sell this rig, this is ONE beautiful truck! why are you contemplating on selling it? I probably could never afford the asking price, but please let me know!
nice rigs!!! i love those 1st gens! now i wanna build one. you're gonna get me in trouble now. runner looks good too. i dare any deer to take on that bumper!
alexhales578us
