Hitch Tire Carrier
SRQ-Runner
I’ll start out by saying that by no means is this supposed to replace something like a full tire carrier bumper that costs $1000 +, but I do feel it is an affordable median between no tire carrier and a full one. This also can be a very nice addition for someone wants to retain their stock rear bumper yet still have the look and function of a rear tire carrier.
In my case I have a full steel bumper but it was designed without a tire carrier and this caused a problem when I went up to 33’s. While I could try and squeeze my 31’s into the stock spare spot, it hung awkwardly low with my bumper being set so high. So I have been keeping the spare in the back on top of my storage box. While this has worked for a while, it’s a pain having a tire take up most of my storage space and worrying about taking the tire out every time I go camping to sleep. So this is where the hitch tire carrier has come in handy.
SRQ Fabrications Hitch Tire Carrier
Link Here
Fabricator: Evan Neise
Stock Price (as shown): $225 plus $55 shipping
Total: $280
Additional Hitch Built into Tire Carrier: $245 plus $55 shipping
Total: $300
Build time: 2-3 weeks
Info:
-Holds up to a 35 inch tire
-License plate bar below tire
-Quick release pin to allow the tire to drop fast and easy
-Option to extend hitch out through the tire carrier so you can still trailer with the tire carrier attached
Install:
Install took about 45 minutes. It can easily be done quicker but my locking hitch pin was giving me trouble. The tire carrier is shipped in a big box that contains two pieces. The first piece is the section that actually slides into the hitch. To keep movement of the tire carrier down, it’s designed to be a tight fit. Using a rubber mallet you, makes it a breeze though. The second piece is the actual arm the holds the tire. You attach this to the hitch part with a grade 1 1/8th grade a bolt along with two washers per side, a locking washer, and a large nut. After doing this, your tire carrier is together. You can then put the pin in that hold the tire carrier in the upright position. Next you’ll remove your license plate and attach it to its new spot under the tire. The carrier comes with bolts to attach the license plate into the pre drilled holds with nuts welded to the back side. Finally it’s time to throw on your tire. There are three studs which are mounted to a plate like most other tire carriers for your tire to be mounted.
Review:
So far it’s been great. While I haven’t done any hardcore off-roading with it on yet, it has done great on the small trails I’ve gone down. I haven’t heard a sound from it yet, even down the dirt roads at speed. The tire will move some off-road, but this is to be expected with it only being held up by a single post into the hitch. Overall I couldn’t be happier with how it turned out. While I still hope to have a full tire carrier down the road, this will get the job done till then. I plan on attaching some roto packs between the tire carrier and the hatch as there is enough room to do so (will post pictures up when the time comes). Also need to still rig up a license plate light. I’m going to go ahead and order some bolt lights from SuperBrightLED as it should make for a quick and easy install.
Pictures:
The tire carrier seems to fit far back in this picture but this is in part because of my hitch location on my bumper. I don't mind this space as I'm going to go ahead and mount Roto Packs between the hatch and carrier.
As you can see, the tire carrier is universal. Included these pictures to show the craftsmanship put into each carrier by Evan.
i like this because it's clean. when you're opening the rear hatch though, does the tire carrier fold all the way down to the ground? If you were loading medium to large sized items, would the tire get in the way and be a hassle?
I had the CBI version of this with the intention of being able to move it from truck to truck.
It was extremely well built with a recovery point built in.
I eventually decided not to use it. It was a major pain raising and lowering a 35" tire and was in the way trying to get crap out of the back of the truck.
OP- i would recommend adding a license plate light...
Yes it's folds all the way down. Obviously it's going to be in the way some, and I'd just being like if I said it wasn't. But I have no problem working around it. The tire does end up sitting pretty far back so you can get between it and your bumper.
Looks like a good solution for some. I can still use my current spare location but will likely do this if I get bigger tires.
Oh, I see the oak tree squiggles are all over your area as well.
Here are some other options that are perhaps more wife or g/f friendly if you need that sort of thing.
Those are really cool. My only beef is the lower part sits close to the bottom where the stock tow package would be on a 3rd gen which is kinda low. But that's part of the pros and cons list of doing an alternative. Still neat.
The one on the red truck sits about 8" above hitch.
The one on the bronze truck sits stacked on top stock receiver. both have different looks.
You are right...the lower your receiver compared to your bumper makes a YUUGE difference in how it looks.
This one is on my list. Pretty fair price of 235 plus shipping and it folds down sideways. Perfect for parking lots. They also took into account departure angle. And you can get the offset mount. Wouldn't have to worry about license plate relocation. Doesn't have the extra hitch mount. But walmart sells that for pretty cheap if that's what you wanted to add to this.
http://detoursusa.com/knucklebone.php
I have been looking. As well. You would think there would be a bigger selection out there. Lots of different rigs could benefit from one of these type carriers.
alexaturner
