Home-made Hood Scoop?
Park
Hey guys I was wondering if any body has ever had this idea before and possibly carried it out. Because I cant find any record of it. Heres the idea: So you go buy one of those ghetto hood scoops at autozone then you smack it on to your hood THEN you use body filler to make the edges curve gradually onto the hood and try to make it look similair to the sport edition hoods. THEN finally you sand down the hood and repaint it and call it a day. Has anyone heard of someone doing something similar to this before? TIA!
it is possibly but because hoods are such a large panel there is risk of flex which could potentially crack any body filler you used to make the scoop flush to the hood. Not every thing needs to be molded into a car though especially a scoop. if it is an aftermarket one it probably comes with some kind of mounting hardware to bolt on or even apply with double sided tape. Personally molding it sounds like too much work, take it from somebody who has auto body experience, that is a lot of sanding. you would be better off just buying the hood with the scoop, from what i have heard you can get them pretty cheap. I was considering just getting some of these louvers <br>
<a href="http://s2.photobucket.com/albums/y33/cobra86/?action=view&current=DSCN0843.jpg" target="_blank"><img src="http://i2.photobucket.com/albums/y33/cobra86/DSCN0843.jpg" border="0" alt="Photobucket"></a>
^ this. Sure it could be done. But go get on the highway and watch your hood. They flex a lot on these things. The filler would crack pretty quickly I'd think.
Credit to you for trying something new though.
Sure, one of those hood scoops is a cute little sticker, and if you bondo it on there it'll be hard to remove later when the bondo starts to crack and it really looks like junk, but I'm sure it's cheaper than an actual factory hood scoop. It's worth noting that while the factory hood scoop may look kinda cool, it's also effectively nothing more than a sticker. There is zero benefit, and some (admittedly minimal) detriment.
If you want a hood scoop and you don't want to spend money on it, maybe do it right. Cut the bracing out of the middle (or wherever you want the scoop), make three more cuts (the front and sides of your scoop), do some bending, and weld in some filler strips. Now you have a REAL non-functioning hood scoop that didn't (if done correctly) cost much more than a few little scrap pieces of sheet metal and some paint. If you suck at that sort of metal work, maybe spring a little for filler.
In the end though, you're not going to be saving yourself a whole lot of money and you went through quite a bit of trouble (even with the factory hood) for absolutely zero gain. It's an expensive and labor intensive sticker. Good for 10hp.
I bet this guy knows a thing or two about them.
If not the real deal hood scoop, I'd rather have the louvers. The idea was good, it's just that it wouldn't last long and end up ruining your hood.
premiumusedautoparts
