Home made storage box
simple
Senior Member
Instead of making a new thread, I'm just turning this into a storage mod thread
Center console shelf
I like storage to be neat and hidden away. This is a weakness of the 5th gen, so I'm doing little things to make it better imo.
Here's a cheap little mod I made to take advantage of the little shelf inside the center console box. I put stuff that I don't need everyday, like a disposable razor, floss, bandaids, mouthwash...just weird little knick knacks that I use. And stuff that I'd rather have out of sight in there.
This is about a $10-$15 mod assuming you have a dremel. Although, the dremel's not necessary.
I used a stiff art canvas board from Michael's which was on sale, some black shelf liner, some form of strong glue(I used rubber cement from a model I'm building), and although probably not necessary, I cut an aluminum strip with my dremel to reinforce the shelf.
First I used a piece of cardboard, the dimensions are roughly 7"x6.75" and once that fit okay, I traced that over the art canvas. The canvas was made out of pretty stiff cardboard as I found out after cutting it. I plastidipped it as a way to coat it. Then I glued on the rubber shelf liner. Glued on the aluminum strips on the bottom. Tried to glue shelf liner on the bottom, which was a mistake...recommend don't do that. Peeled it off and just repainted the bottom. The bottom now looks kinda crappy from the dried glue.
5972182F-834B-4D8D-8E10-12BB5E5E7337.jpg~original
D858B097-9EAE-47E2-A504-6C84D1C6C495.jpg~original
85150596-C5E5-44FB-92B6-40B404D79627.jpg~original
storage box
I had one in the 4th gen. The 5th gen is very... not cargo box friendly with the reclining seats. Its 4-5inches shorter length wise than my old one, but it still fits a decent amount. I could have made it longer by using the driver side wheel well, but I would have run into problems with the jack access. And by putting it on the other side, it acts as a partial cover to the wall compartment which I like.
In the box is a large wrench, tire iron, MRE, a small tool set, a folding shovel and 50' of 550 cord.
6BD55525-D183-43FF-9BC3-5B7B81435989.jpg~original
B3F90E35-DAEB-4C6E-BF59-CE7A1CFF2896.jpg~original
65CD1E9E-AF8B-4EED-89F5-767AA267A1C2.jpg~original
Great job, i would like to see the box extended all the way back over the mounting point to the rear hatch, possibly relocate the 400w and 12v receptacles somewhere on the box where convenient. Possibly even incorporate the side cubby storage into the storage box for more volume... anyone following me?
Cool cargo box. Coming from a RAV4 we are really missing all of the little built-in compartments in the cargo area. This winter I'll have to build something similar.
The seat keeps it in place. I set it to the first incline position because I thought that was the most comfortable setting for daily driving. Also if the seats are down the cargo cover keeps it locked into place. If both those things are gone, it will not stay in place.
And for those interested in making this box or something similar, I highly recommend making the parts out of cardboard first in the car and then tracing it on a piece of wood and doing the cutting that way.
Nice job. I just use a tall tupperware container with bungies to tie it down. Works well but doesn't look as classy as this!
