Homelink Relay or Fuse Location?
mgreezy
My Homelink button was stuck and will no longer operate my garage door. Because this can be used without the key, I assume it was killing a relay switch or fuse, but I can’t find the location or anything in the manual.
Does anyone know where this is located?
It's a dealer added feature, not a factory option, so it just depends on where they tapped into a circuit. If there's no visible add a fuse, it would likely be spliced into a power wire in the overhead console or under the dash (my best guess), assuming this is whats causing your issue.
Homelink is a factory installed option. It comes on SR5/TRD/Trail Premium and Limiteds and TRD Pros.
He didn't specify if his button was on a mirror or not or which model he has, so that doesn't preclude it from being a Port/Dealer add on, which a lot are, so I assumed that if he's blown a fuse, its due to something grounding out that shouldn't.
If it has a button on the overhead console, I imagine it would be as you say.
That said, I would check your 10amp ECU-IG no 1 or IG no2 fuse, and your 7.5amp IG-1.
utkrstam
