Hooting noise
Morania
So whenever I put the Yota to bed after a drive, I hear a hooting noise coming from under the hood. It's a quick noise that sounds like air escaping from a plastic seal. I figured it was a vacuum thingy under there with a sketchy seal.
Now that the weather is warming up some, I can hear the noise a little bit as the temperature rise during the day- the truck hasn't been even started yet.
It's kind of cool. I'm not worried about it, just curious.
It's part of the gas tank vapor recovery system. I used to think it was a valve being operated by the system, but once I heard it happening on my car while the battery was disconnected (installing a winch). So it's just a pressure build up in the system that eventually pushes its way through a valve in a mooing/farting/hooting sound.
Later model trucks have a little chamber built into the charcoal canister box under the hood, some people do mods on their earlier style boxes to add a small amount of volume to the hose - this is apparently enough to change the resonant qualities of the air flow and stop the flatulence.
https://www.yotatech.com/forums/f2/3rd-gen-4runner-evap-canister-buzz-286103/
Oh, I love it. Just wanted to be able to explain it.
We're nearly at Hooter for the truck's nickname.
seltzernator
