Horn install
VT4runnin
I probably should have included this in the FIAMM Horn Install thread but my issue is kind of seperate. I'm trying to install the El Grande Fiamm horn that will sit on the right however I don't have enough cabling. If you imagine looking straight at the two horns, the horn on the right has the connector at 2oclock. The cable won't reach all the way around to connect. If it were at 8 oclock I would be fine, however that means turning the horn upside down which wouldn't work. Did anyone run into the same issue or know of a good fix? Can I buy an cable extender online?
Can you send picks of the horn? With that, somebody might be able to give you some advice.
Cable extender? If you don't have enough wire, all you need are some of these and some 16 ga electrical wire, available at Radio Shack, or probably Pep Boys or Autozone.
LOL, yeah I'm not very mechanic savvy. By cable extender I just meant a new male/female piece with extra wire to extend the current wire. I'll stop by Autozone today to see if they have it. Thanks!
