Horn not working $1000 for a oem clock spring wtf !!!!!
Audio controls work and horn still honks on panic alarm any other ideas ?????
What's the backstory here? Were you working on the steering wheel? Did the horn stop working out of the blue? A little more detail would be helpful. Yes, the clock spring assembly is expensive and could be the culprit. I believe there are also two horns, one for the alarm and another louder one for driving.
Airbag clock spring costs $544 (online part order with discount) for my 4Runner. Full retail is $750.
I know of a lawsuit where a vehicle owner was seriously injured when a technician improperly installed a clock spring. Airbag deployed when the driver turned steering wheel to full lock with their arm draped over the wheel and their head turned about 90 degrees resulting in a broken arm, dislocated shoulder and a serious neck injury.
Check fuses/relay and all. My Matrix horn quit on me so I put a Fiam in but the connector was different so I cut the OEM connector off and used a spade connector that I had laying around. Worked fine for about a year then quit. I removed horn and connected to battery, worked fine, Checked relay, fuse took horn cover off steering wheel and all looked good. Looked at spade connector I had used and it was dull in color, snipped it off and installed a new one and bang! Horn works fine!
You never know!
Ambrose67
