So I finally got my 4Runner, 01' SR5, 4x4 auto with 153k on it...
A few questions...
I know the mileage is a little high, but what maintenance would you guys recommend? The engine runs like a top, very quiet, all fluids look good.. no issues with it really, but I'm curious if there is anything I should be looking out for. The previous owner only had it for about 3 months, apparently didn't like the gas mileage, just bought it for it's good looks
The owner before that was the original owner, and they had traded it in at a dealership. They also said the timing belt and water pump had been replaced, but I'm not sure when..
There is a slight shake when cruising at about 70mph but I've been told that's probably just the tires. It's got the 16" factory wheels with Goodyear Tracker's that have hardly any wear on them.. maybe just a balance issue?
Otherwise, I have the same issue as many, no key fob came with it.. So I've been reading posts around the board, and it's obvious my 4Runner has the standard keyless system. I have the Toyota Security light that blinks, but the real question is - how do I find out which FCC ID# I have, so I don't get screwed and buy the wrong key fob? I want the one that lets me roll down the back window
On another note, it has the stock am/fm/cassette/cd player, and when the dash light's dimmer is on (meaning headlights are on and the dash lights are set at anything other than off or max) there is a slight hum coming through that can only be heard when the volume is low, if I turn the volume knob all the way down, it goes away, a slight turn up and it's back.. does this mean it's coming in at the preamp or amp stage? The amp is seperate from the headunit, right? The frequency of the hum changes with the dimmer level, of course. It was annoying me at first, until I realized that I could turn the dash lights to max and it would go away, but I still would like to know where the problem is.
Oh well, any help/advice/suggestions are truly appreciated.
A few questions...
