Clemsonfan15 said:'99 sits lower than other years. Does the one you are looking at have a locker? If it has both 4 wheel drive and a locker then it is pretty darn capable.
Compared to those other models I'm sure you will like the increase in power, although the V6 leaves a little to be desired in my opinion.
Sloan said:99s are the highest....
its '01-'02 that are the lowers.
How capable are the 3rd Gen 4Runner's, off-road?
I am specifically looking at a '99 SR5 V6 w/ 5-speed and 4x4.
In comparison to a '93 Truck w/ 4x4, 22re, and 5-speed?
I used to have a 1st Gen 4Runner w/ carb'ed 22r --- capable, but underpowered.
thats what I thought...
the regular 99s are the same as 96-99
the 99 highlanders were 1" taller
I don't think that's true. I'm pretty sure my 99 SR5 (non-Highlander) has the tall coils. I know that even without a lift my wife has difficulty getting into it since I took the running boards off, and I have parked next to other 3rd gen 4runners and mine is noticeably taller.
Part of that is because the previous owner went up 1 size on tires (stock size is 265/70/16, same as my Taco's stock tires, current tires are 265/75/16s.)
And yes, I'm still on the stock suspension (which sags a bit in the rear depending on how I park.)
i'm pretty sure that all the Highlanders got them and then it was hit or miss for the rest of the 99's. one way to verify would be to check the color colde on the springs.
