How do you remove the wiper switch?
JPL
Hi All,
My wiper switch needs to be changed in my '06, I have the new one and will attempt to change it tomorrow, any help would be great.
Thanks!
I had to do this a few months ago, when I damaged my switch doing a new stereo install. It's really not difficult at all. First, you remove the plastic steering column shroud, which, if memory serves me, is 4 screws. Your wiper switch should now be exposed. Then, you remove the wiper switch wiring harness, followed by one screw near the top of the switch assembly. Hear is a graphic:
Good luck!
Good luck!
Thanks for the help! It was actually 3 screws for the shroud and 2 on the switch, someone did mention to disconnect the neg from the battery, due to the air bag module in the column, anyway, I also found it easier to remove the harness after I removed the switch, not sure if that was correct, but it worked for me.
Would this be the Switch or the Motor? If it's the Switch, can I replace it with one with a Mist cycle? If so, does anyone have a P/N?
Thanks,
Jerry
AndiGarage
