MSBX4RUNNER
Does anyone have a PDF or directions on how to remove XREAS?
Sorry to jack an old thread, but I hated to open a new one just because I couldn't find my answer. And I have a lot of time in this search for answers! I just bought a used lift from a member on here (thanks 10mile) and I'm weighing my options about installing it ASAP or waiting until my XREAS craps out, because I love the ride and handling. My questions are this:
1: Is it possible to reinstall XREAS once you've removed it, say I were to change my mind about the new ride after discarding XREAS?
2: In general (since I haven't included the specs of my new springs/lift/etc), have very many people removed their XREAS and regretted it? I did find one person on here that was very detailed about regretting their desicion to remove the XREAS and had to buy a new system and instal it with Daystar spacers once they realized their regrets.
Thanks for all the help, you guys and gals ROCK.
You are headed in the right direction. I agree, no telling when your xreas could go. What condition are your current tires in? You'll need an alignment after the install. If your current tires are pretty worn, you may consider waiting on the install until time for new tires. Stock sized tires (assuming that's what you have) will look odd with the 3/2 lift. I'd probably go with 5100 rears, they'll best match the fronts.
I removed my XREAS and Daystar 2.5/1.5 at around 52,000 miles with no leaks. I replaced it with the Toytec Ultimate lift which includes the 5100's all around and I was surprised to find that can barely tell the difference from the XREAS. Off road it made a huge difference though and I don't regret it. If you just plan to only drive paved roads or mild trails you should be fine keeping the Daystar and XREAS but if you want to do serious trails with rocks etc. you'll will start to immediately feel the limitations on the system. Thats the only reason I did the change so early.
I just did a small guide on removing XREAS on my rig when I installed my OLW lift.\
http://www.toyota-4runner.org/4th-gen-t4rs/84725-zombie-truck-2-0-mpav-build-4.html
