How easy/difficult to do the head gaskets
nissanh
Senior Member
Just found a 4runner with bad head gaskets. Wonder how easy/tough the process is.
I've done a corolla head gasket job.
Approximate price to get the head gaskets done (just parts)?
thanks
nissanh
The gasket itself isn't usually the issue its how long it was driven when it blew. If it slow leaked before catastrophic leak you could have cylinder scaring, ring damage etc. if it just blew and the truck was shut immediately off and coast to the shoulder of the road everything may be good. Fwiw, it would have to be a huge savings to take that risk. As I type you could run a bore scope down each cylinder before you buy if the seller will allow to negate some of that risk.
[MENTION=85046]nissanh[/MENTION] [MENTION=91230]iBison[/MENTION] has done the HG repair himself I believe.
My son and I did mine, he's a mechanic so he did most of it. It's not hard, but it is a LOT of work. Print out the pages of the service manual and follow along and double check things. I drove mine for weeks after it first started with no issue. I have not heard of anyone having anything other than a very small leak. Just watch your coolant and don't let it overheat, if it does definitely check your heads.
I had about 900 in it including machine shop work, gaskets, plugs, head bolts, water pump, see in the links below for a breakdown. They say its like a 20 hour job, I think we were under that even with having to take the heads apart after since we didn't measure the shims before, that step isn't mentioned in the manual. If you have questions I will try to answer.
Everywhere I read said get the engine overhaul gasket set, which I did. We replaced all the gaskets and seals we could, valve seals, injector o-rings, exhaust, intake, front seal, crank seal, etc, etc, etc. I had the heads checked and trued up at a quality machine shop. We replaced the water pump, thermostat and housing, one questionable injector, plugs and crank bolt. We broke a couple exhaust manifold studs, you can only buy them at Toyota and they are EXPENSIVE, I found some that worked from autozone. We broke one on the intake I believe. On the intake there are some torx bolts, don't remove those. I used bolts instead of studs on the intake.
Measure your valve shims before you take the heads off and make sure you keep track of where they all go.
Here are a couple of posts I made that you might find helpful, one, valve adjustment, not that hard or expensive, Replacing bearings in pulleys - V6.
Jhunt
