How fast have you gone before switching to 4WD? Manual says below 55 mph.
I find above 5mph but the slower the better (as a rule) is the answer for the best transition 2hi to 4hi.
The official answer is 62mph IIRC. The "real" number is below 100kmh (62.5mph). Remember the T4R is based on a vehicle that sells more in the rest of the world than the US. Most of it's design limits are expressed in Kg's and KM/H's and then converted...
:cheers:
True...Probably in areas that don't have much snow, but more dirt instead. Thus the rust issues.
...I've done it at 60. Anything over I get the beep.
Ditto. Beeps and locks me out until I reduce speed on my '08.
What's the difference between my Limited's 4WD 4Hi (which is always on) and you guy's 4WD 4Hi?
You have full time 4WD with the V8. I/we have selectable 2WD or 4WD, which was exactly why I bought the V6.
85 mph in 4WD without any problems for me last winter. Isn't it only recomended to SHIFT into 4WD under 55, but no limit for driving speed? Thats the way I read into user manual.
So is your 2WD --FWD or RWD?
Thanks! I heard the older nissan pathfinders are FWD.2003 V6 are RWD when 4WD is switched off.
