How frame repair should look
kolelt
This is not my 4runner, and it is not me who did the work. It is a local friend in NJ. Who welds and fabricates for a living. If anyone needs anything welded or fixed in the NJ area. He's a good welder to go to. There have been few photos of guys getting a bad job done on fixing a frame.
PM for his name if anyone in the northeast needs stuff like this done
I wonder if this would be worth doing even though I don't live in the rust belt, I mean the spray thing
Get a gallon of fluid film. Get a cheap brush and gloves. And brush fluid film on the outside of the frame and under body of the vehicle. That's what I do.
And some in spray cans to spray inside the frame through every hole. After a good hose out of course.
Are frame repairs like this expensive?
I have a 97 limited needing about 1 foot of frame repaired behind the rear axel on the driver's side. Frame is completely rotted through where snow/salt must have accumulated against the spare tire. The rest of the frame is good with surface rust.
Is something like the original pic going to cost around $200, $800, maybe more? :confused:
A general idea of cost would be greatly appreciated.
He said that, was $500
Wow, that looks like 1/4" plate and continuos welds., bit much IMO, and those vertical welds are not advised although common on even factory frames and slider installs, fish plating <> is safer as it doesn't cause a vertical crack later on in life.
